18 years agoEP3S150ES VCC/VCCL Resistance to ground
Hi All: We just got a board back, and we are seeing an oddity on the 1.1V supply. We haven't powered the board yet, because of this. Right now we are seeing ~3-4 Ohm resistance to gro...
12 years ago --- Quote Start --- Thanks.. I have it powered. But so far no joy on configuration. Both JTAG and AS fail. JTAG is flaky right now, some times it scans, but most the time it doesn't. If it scans, It then tries to program and says config done failed to go high. Any ideas? So far all the supplies are up and ok, and I've double/triple checked the pull-ups/downs in the configuration area. --- Quote End --- Hello, i have the same issue with Stratix 3 FPGA (EP3SL150fF1152C4N). Resistance at uninstalled and unprogrammed FPGA between Vccl 1.1V and GND is about 2 Ohms, but i am afraid to power it on, because Stratix 3 is expensive for me. Did you resolve this problem? Does this mean that chip is defective?
