16 years agoEP3C40F780C8N devices damaged after reflow
Hi All, Has anyone had any production problems with the EP3C40 having low resistance shorts between IO pads and ground after reflow? We are getting a lot of boards failing this way. Thin...
16 years agoDid you x-ray the board? Or inspect the inner ball connects with an endoscope camera? I rather expect solder than device internal shorts.
P.S.: I didn't read the post completely. You verified internal shorts. That's rather unusual in my opinion. Did you keep the storage time after opening the dry device packing. Risk of package delamination due to adsorbed moisture is the most critical issue, I think.
