15 years ago
EP3C25 nStatus 1V
I have five EP3C25 borad, 3 of them are working well. But the rest 2 will sometimes boot fail. The working mode is AS or fast AS from EPCS4. There're 10K pull up on nStatus, nConfig, Conf_done, MSELs are 010 or 101, tied to GND or 3V.
Fail boards are in common that the nStatus pin goes from 0V to about 1.1V after power up or after the nConfig is tied to ground then released up, no DCLK or other signals from EP3C25. On the success boot, it can load configuration from EPCS4, while the nStatus is about 1.5V and will slowly move down to 1.2V.
Do you have any idea on this situation? Thx.
    Could you look at those signals with a scope instead of a voltmeter?
    Which package is it? If it's a EP3C25E144 you must check that the chip's exposed bottom pad is properly soldered to ground.
