15 years agoEP2C20Q240C8N and giga ethernet
Thank you for your reply. 1- Regarding the input clock frequency “fHSCLK”, from the previous mentioned tables, the lowest value of its maximum is 155.5MHZ. So, the lowest value of the max...
15 years agoYes it is. But you will need to contact Marvel to get a datasheet of that PHY chip, as it isn't publicly available and requires an NDA.
