15 years agoEP2C20Q240C8N and giga ethernet
Thank you for your reply. 1- Regarding the input clock frequency “fHSCLK”, from the previous mentioned tables, the lowest value of its maximum is 155.5MHZ. So, the lowest value of the max...
15 years agoThank you for your reply.
Is the Marvell "88E1111" Ethernet Transceiver considered as PHY with a parallel RGMII or GMII interface? BR
