15 years agoEP2C20Q240C8N and giga ethernet
Thank you for your reply. 1- Regarding the input clock frequency “fHSCLK”, from the previous mentioned tables, the lowest value of its maximum is 155.5MHZ. So, the lowest value of the max...
15 years agoYes, as I just told you. You should just be careful about the number of pins that you'll need to communicate with the PHY (and find a proper PHY, of course).
