15 years agoEP2C20Q240C8N and giga ethernet
Thank you for your reply. 1- Regarding the input clock frequency “fHSCLK”, from the previous mentioned tables, the lowest value of its maximum is 155.5MHZ. So, the lowest value of the max...
15 years agoThanks a lot for your co-operation.
can i implement 1 Gbps ethernet using “EP2C20 FPGA” external PHY with a parallel RGMII or GMII interface? BR
