15 years agoEP2C20Q240C8N and giga ethernet
Thank you for your reply. 1- Regarding the input clock frequency “fHSCLK”, from the previous mentioned tables, the lowest value of its maximum is 155.5MHZ. So, the lowest value of the max...
15 years agoThank you for your reply.
1- Is there any problem to handle the 1Gbps Ethernet using the“EP2C20Q240C8N", Taking into consideration that the"EP2C20Q240C8N" can transmit and receive data through LVDS signals at a data rate of up to 640 Mbps and 805 Mbps < 1Gbps? 2- I use the cyclone ii device of the part number "EP2C20Q240C8N". My application needs frequency of 125MHZ. can the cyclone II “EP2C20 FPGA” support this frequency? Your reply will be highly appreciated. Waiting your feedback. Thanks &BR
