16 years agoEP2 won't AS configure, nCONFIG stuck lo
EP2C5Q208 will not AS configure itself. Circuit is exactly as Fig. 13-7, page 13-20 in Cyclone2 Device Handbook, Vol. 1 for a single device. Configuration device is EPCS4. (Using USB Blaster Quart...
16 years agoThe problem as described at post# 1 was resolved by observing I had two of the configuration signals connected together that should not have been. After fixing this, however, Active Serial Configuration Stage does complete, i.e. CONFIG_DONE never goes high.
Also, I still have the problem that programming the EP2C5 with JTAG does not work. The Programmer message states: Info: Configuration succeeded -- 1 device(s) configured but the FPGA does not do anything programmed. I will start another thread describing the latest trouble.
