Val's avatar
Val
6 years ago
Encapsulating HLS streams
Hi all,
As I am working with multiple input streams, I'd like to encapsulate them within a class/function, etc
The HLS Reference doc clearly specify not to inherit Stream or wrap them into structures or array, but says accessing them by reference is possible.
However, I keep getting the following error when I try to read or write from a reference to a stream
Cannot resolve stream parameters.  Streams should be accessed with a non-aggregate global object or component parameter passed by reference
Any idea why?
Best,
Val
  • MEIYAN_L_Intel's avatar
    MEIYAN_L_Intel
    Based on my understanding, you are using the command eg:i++ stream_test.cpp -v -march=x86-64 -o test-x86-64 or make test-x86-64, am I right?
    If yes, this command is used to compile the C++ source
    code to an x86-64 binary executable and run the generated executable on your
    CPU.
    You could able to use command eg: make test-fpga or i++ -march=Arria10 stream_test.cpp -o test-fpga
    to have a .prj directory and you could able to find a .qpf file to open in Quartus Prime software.
    Beside, I could not able to compile the file with error: 'utils.hpp' file not found. Could you try to attached the full design file?
    MEIYAN_L_Intel
    From the code you given, a component cannot read and write to the same stream (that would require the AVST interface to be both a source and a sink at the same time, and that is not possible).
    Could you attached a file with full design code for me to further investigate?
    • Val's avatar
      Val
      Hi
      Please find attached the src file. It compile with x86 but fail to generate fpga code.
      Best,
      Val
  • Val's avatar
    Val
    Note:
    You cannot derive new classes from the stream classes or encapsulate them in other
    formats such as structs or arrays. However, you may use references to instances of
    these classes as references inside other classes, meaning that you can create a class
    that has a reference to a stream object as a data member.
    I first missed this sentence in the HLS Reference doc and tried encapsulating `stream` and stream_in` in a struct.
    In some cases, I get a silent failure at `_fpga` time, where compile is successful, and test also runs successfully but nothing seems to be read from the stream (successful blocking `read` but no data, or unexpected)
    Best,
    Val
  • Val's avatar
    Val
    Hi @AMEYE13​ ,
    Thanks for getting back to me.
    Let me provide a bit more information...
    Basically, I am trying to encapsulate `stream` and `stream_in` in an object to be able to operate on my inputs more easily.
    Would something like that possible?
    template <int W>
    class InputClass
    private:
        using input_type = ac_int<W, false>;
        input_type word_;
        ihc::stream<input_type> & stream_;
    public:
        // Constructor
        InputClass(ihc::stream<ac_int<input_type>> & stream)
        : stream_(stream)
            //std::cout<< "Constructor" << std::endl;
        _read()
          stream_.read();
        _write(input_type & in)
          stream_.write(in);
    ihc::stream<input_type> myStream1;
    ihc::stream<input_type> myStream2;
    ihc::stream<input_type> myStream3;
    component void
    my_component()
    InputClass myInputClass1(myStream1);
    InputClass myInputClass2(myStream2);
    myInputClass1.read();
    myInputClass1.write(...)
    Please let me know if this would be an acceptable design, and if so, why I can't have it running.
    Best,
    Val
    MEIYAN_L_Intel
    May I have the design code and .log file for further investigate?
