11 years agoEN2342QI thermal dissipation
Hi, I have some concerns about thermal dissipation of the EN2342QI on space applications. The major concern is about those power pads on the bottom of the chip that specifically says "is not ...
11 years agoI don't know the answer but I'll move this to the non-SoC section of the forum since this section is for the SoC FPGAs which have ARM processors inside them.
Also can you clarify what the question is about? I can't tell if you are asking if there will be sufficient heat dissipation through the pads to the board or if your concern is power reliability related.
