17 years agoemulation and simulation
Hi. I have read some articles(wikipedia and so on) and confuse on the meaning about the emulation and hardware emulator. Besides, FPGA prototyping is very near to emulator. My question is:...
17 years ago --- Quote Start --- simulation and modeling is an another issue for me. --- Quote End --- To simulate a system using another system you need to model it first. --- Quote Start --- "You can also produce another hardware platform to directly model your hardware and this is emulation without using software." Is that mean FPGA(or any programmable logic)? can you give some example. --- Quote End --- fpga prototyping for asic target is a type of emulation(though commercial emulators add extra debug features, not just fpga). Using a cyclone device to test a program meant for stratix is also emulation. --- Quote Start --- "If you are modelling software itself with another software then this can be viewed as emulation as well." What do you mean by modeling software itself? --- Quote End --- in fact the word emulation was first coined for software. Example, you design FIR filter and model in your PC. If your final target is a DSP(software) based FIR then you are emulating it on the PC(if we ignore the difference of instruction sets between PC and DSP). If your target is FPGA then you are simulating it. Don't worry much about terms, they are context dependant, relative and may vary. All you need is to know first we have two systems, one used to copy the other. Simulation models a system(e.g. your fpga) using a different system(PC software). Emulation models like by like(as close as possible, possibly never exactly).
