Emulated LVDS
hello everybody :)
i'm using Stratix III. what is the diffrence between the dedicated LVDS IO to the emulated LVDS IO? thanks;)7 Replies
Emulated LVDS is actually voltage mode: Signal is sent to the positive pin, same signal go through one not gate inside FPGA and be sent to the negative pin.
Dedicated LVDS IO buffer is current mode. - Altera_Forum
As a practical difference, the achievable data rate is considerably lower.
can I reach 500Mhz with the emulated output LVDS channles?
In the Stratix III Device Handbook, you find table 1–24. high speed i/o specifications
It tells, maximum LVDS data rate is 550 MHz with LVDS_E_3R IO-standard and C2 speed grade. - Altera_Forum
And which maximum data rate can i achieve in cyclone III EP3C16Q240C8N ? In datasheet i found only for Cyclone III LS mini LVDS max.speed 311Mbps. It is same in Cyclone III ?
Thank you. - Altera_Forum
Thanks for opening this thread, it answered my question.
However, I have a quick follow-up question: It says about emulated LVDS in the pin connection guidelines: "External resistor network is needed for emulated LVDS output buffers." What is meant by that? Thanks Adam - Altera_Forum
You want to read Cyclone III Device Handbook, Chapter 7. high-speed differential interfaces in the cyclone iii device family
See e.g. Figure 7–3. LVDS Interface with External Resistor Network on the Top and Bottom I/O Banks For other devices than Cyclone III, do a manual text search for "emulated LVDS".
