AGofs
7 years agoEmulated LVDS outputs and Quartus pin planner
At "CycloneV device handbook" wrote: "Emulated LVDS, RSDS and mini-LVDS output buffers use two single-ended output buffers with an external single-resistor or three-resistor network, and can be tri-...
SreekumarR_G_Intel
7 years agoAs per my understanding you have to use the ALTIOBUFF IP to instantiate the Buffer. You can check with design without adding and with in RTL viewer. :)
Thank you,
Sree
