AGofs
7 years agoEmulated LVDS outputs and Quartus pin planner
At "CycloneV device handbook" wrote: "Emulated LVDS, RSDS and mini-LVDS output buffers use two single-ended output buffers with an external single-resistor or three-resistor network, and can be tri-...
SreekumarR_G_Intel
7 years agoI think if you are using single ended buffer ,then the IO Standard should change to single end.Can you check your IO standard setting in the assignment editor ?
Thank you ,
Sree
