EMIF DDR4 STRATIX 10 ,QUARTUS PRIME PRO 20.1
Hi Venkatesh,
I think the time for finishing calibration should be around 30 minutes or more but it's depends on the device that has been used.
Is there any transaction in the log?
I think you need to let the design run -all and finishes the simulation.
It's will give you the result at the end.
Adzim
YES sir, I did run -all only ,its been more than 2 hours ,still calib_success is low only!
I have been using Stratix 10 EMIF.
in log:
initializing RAM with calibration code ... ed_sim.emif_s10_0.emif_s10_0.arch.arch_inst.io_ssm_inst.io_ssm.inst.<protected> @ 2750 ps
after this empty.
what could be the issue?
Sir,do you have any code for custom data write and read instead of traffic generator?
- VenkateshK4 years ago
one more thing sir,
at the end of compilation ,getting critical warning "DDR4 Timing Requirements not met".
In SDC file, I have created clocks for pll_clk and user_clk!
Is problem is related to timing issues?
