12 years agoEmbedded Command Shell 13.0sp1 Problem!!
Below is the picture showing the DS-5 does not detected in embedded directory ..what is it actually means? izit is the causes that eclipse command cant start at the embedded command shell? And I alre...
12 years ago --- Quote Start --- I had a similar problem, in which case, I had downloaded all the DS-5 files but not run the complete installation for it. Once I did, the error disappeared. --- Quote End --- Hi,surabhisgp, thanks for your reply. what mean of downloaded all the DS-5 files but not run the complete installation for it? A bit confused about "not run the complete installation for it" ? Is you mean that during the installation process of SoC Embedded Design Suit (EDS) software I need to change somethings? thanks .
