17 years agoElectronics Newbie question concerning LEDs
Hi all, I am an electronics newbie, and I am trying to design an guitar that has a light up fretboard. To do this I need to control about 120 individual, single color LEDs, and I am having trouble...
17 years agoWhen using many outputs with higher current, also the maximum ratings for output groups should be considered. For Cyclone II and III, 20 mA per pin is generally possible. You should avoid however to switch all pins simultaneously.
I generally agree with the opinion, that there are more economic options to drive a large number of LEDs than using a FPGA. If you want to add a few ten outputs to an existing system, it can be meaningful of course. External, serial interfaced drivers for slow and medium speed signals, e.g. a LED matrix, have the basic advantage of simplifying signal routing. This can be a sufficient reason to use them, I think.
