12 years agoEight channel data Transmission
Hi, I am doing a project in which I have to transmit eight channel data either through one or two channels. Each channel data rate is 320MHz and frame rate is 40MHz but data is DDR. I have o...
12 years ago --- Quote Start --- The Stratix 4 GX has serdies transcievers capable of 8.5 Gbps, Do you have any of these IO's available to play with? Pete --- Quote End --- Hi, Thanks lots for reply.Yeah I tried with GX but the problem is that output pin assignment requires IO voltage standard PCML which is not available for the available pins on the customized board. Thanks Punit
