14 years ago"easy stuff" - using a clock within a process...
Hey guys, I am totally new in VHDL and got a DE2-151 for making my first experience with this stuff. So I wrote an easy program, but got a (maybe simple) error I am trying to understand. ...
14 years agoThere are two types of statements in VHDL: concurrent and sequential.
Concurrent statements are placed directly in an architecture, and all concurrent statements are executed in parallel. Sequential statements are placed in a process and are executed one after the other. The if keyword can only be used as a sequential statement, so can only be used in a process. The concurrent equivalent would be a conditional assignment:library IEEE;
use IEEE.std_logic_1164.all;
entity morse_1 is
port (s1: in std_logic;
seg7: out std_logic_vector(6 downto 0));
END morse_1;
architecture structure of morse_1 is
begin
seg7 <= "0000001" when s1='1' else "1000001" when s1='0' else "XXXXXXX";
end structure; You don't always need a clock. If your function is just here to read an input value and provide an output depending on that value you can do it without a clock. You will require a clock when you need to have registers that must hold a value
