17 years ago
Easy design with the VIP suite
I am learning how to use the VIP suite on a cyclone III C25 board. I put a memory interface (flash, ssram... which is working), a oc_i2c_master, a test generator pattern and a clocked video output. I managed to compile the project but I don't have anything in output.
I chose :
Active pixels : 800
Active lines : 600
Pixel fifo size : 800
H sync : 80
H front porch : 16
H back porch : 160
V sync : 3
V front porch : 2
V back porch : 21
For the test generator pattern, I chose :
Max image width : 800
Max image height : 600
RGB, color plane configuration in parallel, progressive output, color bars
Do someone has an idea ? If you need more details, just ask me.
Myriam
