12 years agoEagle ulp script to generate FPGA schematic connection directly from qsf?
I use cadsoft eagle to create schematics and pcb. I use the "make-symbol-device-package-bsdl.ulp" script to create FPGA library. But then I have to connect manually each fpga pin to a wire, label it... I am designing a board with a F40 FPGA and I don't want to do that. It takes to munch time and errors are very hard to find. Moreover any quartus pinout modification is a nightmare :-/ So I am looking for a script to: 1) verify that the FPGA is present on the selected schematic sheet 2) parse qsf file 3) create wires connected to corresponding fpga pins and correctly labelled example: - select a schematic sheet with a fpga - run script (with qsf and fpga part name as input) set_location_assignment PIN_R19 -to epcs_clk => a wire named "epcs_clk" is created, labeled and connected to fpga pin R19 Is it possible to write an ulp script able to do that ? Thanks in advance for advice.No RepliesBe the first to reply
