14 years ago
Dual Port Ram problems : Synthesizes error with one or two clock signals
I was running in a problem and can't find a way out . Although there are already a lot of posts concerning problems with dual port rams, I couldn't found a solution. I am using a DE1 board, based on the CyclonII EB2C20F484C7, using Quartus 9.1, SP2. My goal is a dual clocked true dual port ram to be able to read/write on both ports. I was trying the ALTERA altsynram and altpram megafunction with the frustrating result: Selected device has 52 RAM location(s) of type M4K. However, the current design needs more than 52 to successfully fit. I still can't understand this, because I striped down my design to: 6200 16 Bit words which results in a usage of 25 x M4K blocks from 52 available M4K blocks.
Anyway, I decided to write my own dual port ram code in verilog (See my posted code) . First time, it was looking good: I was able to write to port A and read from port A and I was also able to read the written data from port B ..... BUT--- I was not able to write data to port B. With reference to to the post from ammar ( September 23rd, 2010), I was in th opinion that my problem is related to the usage of 2 clocks. I did write a clock-domain- mux ( code also posted ) to bring my dual port ram design up and running with one clock source . ..... BUT--- the same problem. synthesizes error
I do not know how to proceed now any more and every help is very welcome.
Datails concerning my project can be obtained from my homepage.
My questions:
A) Is my verilog code wrong ?
B) Is the CyclonII EB2C20F484C7 to small or did I use the wrong libraries ?
May be you also have other ideas , how I can solve the problem differently
Many thanks in advance,
Reinhard
    Hi Frank,
    thanks for posting your setup. I will try it via import your setup in my environment. I am sure, the problem is related to myself. I am still a QUARTUS beginner...
    Regards, Reinhard
    Did you close the project before inserting text to the *.qpf file? Otherwise, the edit will be ignored and overwritten, when closing the project. Performing a tcl command or modifying settings in the IDE will take effect immediately.
    the problem is fixed. Dual ported Ram with 2 clocks is up and runnig. The remaining problem is a feature of the EB2C20F484C7 with only 52 4K block.
    Many thanks for your help, especially to Frank. Regards, Reinhard
    Thx~!I’ll try it:):):)
    --- Quote Start ---
    It's always instructive to read the Quartus error message completely:
    The interesting point is the reference to Cyclone II errata sheet. Cyclone II early revisions had a silicon bug that is handled by a workaround in Quartus, unfortunately doubling memory resource consumption for single port and not working with true dual port RAM at all.
    Presuming you have EP2C20 Revison B chips, all you have to do is to add a synthesis parameter to your design settings. Use the below tcl line or enter it under default parameters. You should also refer to the Cycclone II errata sheet to learn more about the issue.
    set_parameter -name CYCLONEII_SAFE_WRITE VERIFIED_SAFE
    You can implement 13000 words DP RAM in your device using this settings.
    Frank
    --- Quote End ---
