15 years agoDual Port Ram problems : Synthesizes error with one or two clock signals
Hello, I was running in a problem and can't find a way out . Although there are already a lot of posts concerning problems with dual port rams, I couldn't found a solution. I am using a DE1 boa...
15 years agoDid you close the project before inserting text to the *.qpf file? Otherwise, the edit will be ignored and overwritten, when closing the project. Performing a tcl command or modifying settings in the IDE will take effect immediately.
