Dual Configuration IP does not trigger reconfiguration in MAX 10
Hi MJone6,
Did you try to read Read reconfiguration trigger status to check the actual error? I have migrated the existing AN741 example design from the v16.1.0 design store (in the link below) into Quartus Prime v18.0 today and tested successfully.
You can refer to the attached .zip file which contain the designs. Both the .qar designs has simple LEDs design to indicate different image between factory image (CFM0) and application1 image (CFM1/2). There is no issue with the Dual Boot IP that I have tested today. You can use the example design to compare with yours if there are any difference settings.
Nooraini
- RVadl25 years ago
@Nooraini_Y_Intel Hi, I do not have the Nios 2 process license. I would be great if you can post the .pof files also for the above project which will help us in testing the working of RSU without compiling the project.
Thanks in advance.
