17 years agoDSP cycloneII dev. kit : how to remove dac transformer ?
I'm trying to get some low frequency signals from DAC converter. It's not possible because of T1 transformer cutoff frequency What is the frequency - bandpass ? Why this transformer ? How to...
17 years agoThank you for the reply.
Unfortunately, a wire between T1.6 and T1.3 produces only a positive signal to the output. If I want to get negative signals, it is necessary to use an amplifier OP680, with +5V/-5V supply power, 4 additional resistances (500ohms) :( Unfortunately, even on terrasic adc/dac daughter card, there are transformers on the DAC outputs. Do you know a card without this transformer? thank you in advance, ssiami
