FPGAOLOG
5 years agoDSP: chainout = ( (ay+az)*ax) + ( (by+bz)*bx) + chainin
Arria 10 DSP: I am trying to realize chainout = ( (ay+az)*ax) + ( (by+bz)*bx) + chainin According to the documentation diagrams and tables, systolic form should support this. But when I set az/bz t...
- 5 years ago
Sorry for the delay. I might have overlooked this. Thanks for contacting me. For your information, I have looked into the DSP block architecture in documentation and understand that there should be no issue to implement your target operation.
As I tested with the A10 Native Fixed Point DSP IP, I am able to replicate similar error with your configuration. After further debugging, I found that the right option for the ay' and by' operand source should be "preadder" for your target operation. After I switch to "preadder", the error goes away and the IP Block Symbol also looks correct. You can try on your side to see if it works.
