11 years agoDS-5 debugger "run" or "start" option lead HPS to reset
Hi, I have 2 boards with Cyclone V SoC. One is the Arrow SoCkit and the other is our custom one. There are DDR3 SDRAM installed in Arrow and LPDDR2 SDRAM installed in custom board. I've made prelo...
11 years ago --- Quote Start --- Can you copy the output from u-boot as well? Does it report that calibration has passed (see below as an example) on your board? --- Quote End --- This is my terminal output:
U-Boot SPL 2013.01.01 (Jan 28 2015 - 17:56:44)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 300 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 3125 KHz
CLOCK: QSPI clock 3125 KHz
RESET: COLD
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 512 MiB
SDRAM: Scrubbing 0x01000000 - 0x02000000
SDRAM: Scrubbing success with 27 ms
SDRAM: Scrubbing 0x00000000 - 0x01000000
SDRAM: Scrubbing 0x02000000 - 0x20000000
So it's ok with SDRAM calibration. Furthermore I've done a simple write/read test over SDRAM address space and it was successful. --- Quote Start --- If you try the following, does this work on your custom board? Code: set semihosting enabled false loadfile "u-boot-spl.axf" 0x0 set semihosting enabled true delete tbreak spl_boot_device run wait loadfile "hwlib.axf" 0x0 start This will wait for uboot to reach a safe location in the code. --- Quote End --- I've tried it excepting enabling semihosting (I do it after preloader due to it is unhosted one). Here is output in debugger: +reset system
+stop
WARNING(CMD315): Target is not running
+set semihosting enabled false
+loadfile "C:\workspace\arm\Altera-SoCFPGA-HardwareLib-16550-CV-GNU\u-boot-spl"
Target has been reset
Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF67A3 (size 0x67A4)
Loaded section .rodata: S:0xFFFF67A4 ~ S:0xFFFF87E6 (size 0x2043)
Loaded section .data: S:0xFFFF87E8 ~ S:0xFFFF94EF (size 0xD08)
Entry point S:0xFFFF0000
Execution stopped at: S:0xFFFF0004
S:0xFFFF0004 40,0 ldr pc, _undefined_instruction
+delete
All user breakpoints deleted
+tbreak spl_boot_device
Breakpoint 1 at S:0xFFFF14AC
on file spl.c, line 71
on file spl.c, line 81
+run
Reloading program
Starting target with image C:\workspace\arm\Altera-SoCFPGA-HardwareLib-16550-CV-GNU\u-boot-spl
Running from entry point
+wait
Execution stopped at breakpoint 1: S:0xFFFF14AC
In spl.c
S:0xFFFF14AC 71,0 {
Deleted temporary breakpoint: 1
+loadfile "C:\workspace\arm\Altera-SoCFPGA-HardwareLib-16550-CV-GNU\hwlib.axf"
Loaded section .ARM.exidx: S:0x00126694 ~ S:0x0012669B (size 0x8)
Loaded section .text: S:0x00100000 ~ S:0x0012661F (size 0x26620)
Loaded section .eh_frame: S:0x00126620 ~ S:0x00126693 (size 0x74)
Loaded section .rodata: S:0x001266A0 ~ S:0x0012720F (size 0xB70)
Loaded section .data: S:0x00127210 ~ S:0x00127BC7 (size 0x9B8)
Entry point S:0x00100040
+set semihosting enabled true
Semihosting server socket created at port 8000
WARNING(TAB139): Semihosting was enabled after the target had started running so may not work correctly. Enable semihosting in a target initialization debugger script or with an image symbol instead
+start
Starting target with image C:\workspace\arm\Altera-SoCFPGA-HardwareLib-16550-CV-GNU\hwlib.axf
interrupt
S:0xFFFF0004 LDR pc, ; = 0xFFFF0020 And I need to stop it manually because it hangs. Have you more ideas? ) Thank you for response. --- Quote Start --- I'll ping the software folks on my team to see if they have any ideas, unfortunately I haven't run much software on the SoC yet to know if something else needs to be done. You should hear back tomorrow, if not post here to send me a reminder. --- Quote End --- Thank you, I am waiting for your response )
