12 years agoDS-5 debug stop command
Hey all each time that I load my program press run and stop it within the debugger. the Disassembler shows that I am currently located in a different location (0x000008FC) where my code is ...
12 years agoOn start all peripheral interrupts is disabled (pins IRQ and FIQ of proc masked), and all serious exceptions as Bad Command or Bad Address Of Read is impossible to ban.
I also often see address 0x000008FC 2 month back, while suspect of role .ds-files in DS-5 terrible debugging process ! :) Preloder code must be runned necessarily with strange dancing of commands ! :) Pitifully that in ug_soc_eds.pdf is no introduction in these .ds-scripts. Best way to fast write our program -- use working in board original Altera example as "Hello World" with our gradual remaking. Then touch gradually debug settings in "Run/Debug Configurations..." and see to shifts... And if you want anyway "smash" current program in CV -- zip current project folder and upload here, only with exported your Debug Configuration ".launch". For this need come to menu File/Export..., there select Run/Debug+Launch Configurations, press Next>, and checkbox your program in "DS-5 Debugger", select program folder in "Location:" in order to get current .launch from/for DS-5 settings.
