Your region of memory "0x00100000" at first is good ("Loaded section .text: S:0x00100000 ~ S:0x0010E297 (size 0xE298)" is successful), and after "+start" bad image ("Entry point S:0x0010B298") is damage all.
If you make image ucosii.axf with "Entry point S:0x00100000" or "Entry point S:0x00100040", then running will be ideal.
If running was even from 0x0010B298 ("Running from entry point"), Preloader don't know about this.
Use Disassembler window to stepping in asm-mode, load your bad "
D:\my_experiment\hwlib\Micrium\Software\EvalBoards\Altera\Cyclone-V-Dev-Kit\GNU\Ex-1\ucosii.axf" with "loadfile" command after runned to main() Altera-s HWLIB example, as I describe long ago.
If my words is incomprehensible, ask greater ! You must see start of normal application with "B" on begin and your ucosii.axf with function codes at start.
Method will be in tuning linker scripts, I don't know there.
Or ask UCOS site, may there is solutions.
