12 years agoDrive pins to ground instead of using real ground
Hi, this might seem like a stupid question but I dare to ask. :) I have an external peripheral device which I need to connect to a Stratix 5 GX FPGA via an FMC add-on card. The add-on card ...
12 years ago --- Quote Start --- If your signal return path current needs to take this path, then the current needs to go through the FPGA I/O pin in the wrong direction. --- Quote End --- There's no "wrong direction" for a CMOS output stage. Of course the return current will create a voltage drop across the output transistor and also ground bounce according to its dI/dt. In so far it's not a perfect ground. But in terms of signal integrity of the ribbon cable still better than nothing.
