AGofs
6 years agodownloading .jic into IS128LP128 (8-pins) and connection between CycloneV and IS128LP128 (8-pins).
I'm using Quartus-II Rev. 18.1 in order to program .jic file into ISSI IS128LP128 flash memory at active serial mode, but without success. 1). How should I connect IS128LP128 (8-pins) to Cyclone-V-G...
JohnT_Altera
6 years agoHi,
If you look into ISSI (Datashee) where the pin SI is the same as ASDI of EPCS/EPCQ and SO is DATA.
