17 years agoDownloading FPGA's configuration file into a flash memory
hi, I am working with a development kit (cyclone II) from Altera and I would like to download the configuration file of my FPGA into the flash memory of my development board so that it can work st...
17 years agoThank you for your reply. I also believe the problem is that I use a time limited version. I use a flash memory interface (CFI) created by Altera (it is a DE component) which address width is 22 in bits and which data width is 8 in bits also. the flash memory capacity is 4 MB.
Tell me if I am not clear enough or if you do not understand the way I write english (I am French!). thank you for your help éléa
