17 years agoDownloading FPGA's configuration file into a flash memory
hi, I am working with a development kit (cyclone II) from Altera and I would like to download the configuration file of my FPGA into the flash memory of my development board so that it can work st...
17 years agoYou shouldn't have to explicitly create the RBF file. The programmer will do it for you. The problem I believe (and I may be mistaken) is that you can't create an RBF from a time-limited SOF file. So the sof2flash command is failing.
You may be able to do this another way. What type of flash are you using? Jake
