Shark121
5 years agoDownloading Error when both 3V I/O & tranceivers are used in a project
I use a Avst-PCIe IP in my project, which has a 3V I/O pin for reset, and tranceivers's pin assignments for tx/rx channels. After compilation, I downloaded the .sof file into device use Qua...
JohnT_Altera
5 years agoHi,
May I know if you are using embedded USB-blaster II? Have you try to reduce the TCK frequency? How many device is in the chain?
Shark121
5 years agoHi,
Thank you for reply!
I'm using USB-blaster, not USB-blaster II.
I replace the OSC from 24MHz to 6MHz in the USB-blaster, the TCK frequency slowed, but my problem is still there.
Only one device in this downloading chain.
Expecting for your reply!
