Shark121
5 years agoDownloading Error when both 3V I/O & tranceivers are used in a project
I use a Avst-PCIe IP in my project, which has a 3V I/O pin for reset, and tranceivers's pin assignments for tx/rx channels. After compilation, I downloaded the .sof file into device use Qua...
JohnT_Altera
5 years agoHi,
Can you try to update your Quartus to 20.4? You may refer to https://www.intel.la/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2020/error-18950--device-has-stopped-receiving-configuration-data.html for more information
Shark121
5 years agoHi,
Thanks for your answer!
I update Quartus to the lates 21.1, but it doesn't work, the appearance is same.
Btw, my device is Stratix 10(1SX280 series).
So, is there any other possible solutions? Thank you !
