VKara9
7 years agoDownloading ELF process failed
Hello, I am a new user of Nios II. I would like to use my friend project but it gives "Downloading ELF process failed." The project work on my friends computer. I try to do a simple "hello world pro...
AnandRaj_S_Intel
7 years agoHi,
Can you try by creating new eclipse project?
Program .sof file first and than program .elf by clicking on run as-> Nios II Hardware.
Anand
VKara9
7 years agoHello Anand,
I did not understand, what you mean by "Program .sof file first and than program .elf by clicking on run as-> Nios II Hardware. " Firstly, I create my qsys model. Then, I go Programmer and add .sof file and Start it. Finally, I launch Nios II and create a Nios II Application and BSP from template. After building, I click run as ->Nios II Hardware and it gives the same error.
By the way, when I click Run Configuration-> Target Connection-> System ID properties, the IDs are "Not Found" as shown below. Do you think that this can be reason of the fail?
Best regards.
Vefa
