14 years ago
Downloading ELF Process failed of Project
Good night everybody , I have problem of QuartusII 10.1sp1 .
My user chip is CycloneII EP2C35FC8 , when my sopc builder use
Pll、SDRAM、FLASH、MCU、JTAG , I can run as hardware of holld_world .
(Eclipse - Application and BSP from Template)
But , when I return sopc builder and add EnthModule、DMA(*2-RX、TX)、
onchip momery(4096bytes)、timer . And Auto-Assign Base Addres、IRQS.
Compilation after , I run as web_server_socket(rgmii)
(Eclipse - Application and BSP from Template) ,
but message tell me , downloading elf process failed .
So , I try again run as holld_world , but message still tell me
Would like to ask anyone encountered a similar problem : ( ?
    Dear Daixiwen
    My project of software at the \Myweb_server_bsp\drivers\src
    indeed have altera_avalon_tse.c , and inside file , indeed have
    support about 88E1111 message .
    But I still not understand , my led indicate denormal of reason .
    (LED_LINK1000 Right , LED_LIN100 Unright...)
    And about MDIO communication problem, I not understand your mean..
    Dear Daixiwen
    LED indicate is solve (normal : LED_RX、LED_DUPLEX、LED_LINK100)
    Because the problem from my pin planner of voltage config .
    (need set to 2.5V Level)
    But NiosII message still tell me
    error : mac group[0] - no phy connected!
    error : phy[0.0] - no phy connected!speed=100,duplex=full
    MDIO communication ... I will try : )
    Dear Daixiwen
    I can catch PHY!! indeed is hardware of MDIO problem .
    Now NiosII message tell me
    Your Enthenet MAC address is 00:07:ed:ff:3d:e5
    prepped 1 interface , initalzing...
    [tse_mac_init]
    INFO : TSE MAC 0 found at address 0x05002000
    INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group[0]
    INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
    INFO : PHY[0.0] - Restart Auto-Negotiation , checking PHY link...
    INFO : PHY[0.0] - Auto-Negotiation PASSED.
    MARVELL : Mode changed to RGMII/Modified MII to Copper mode
    MARVELL : Enable RGMII Timing Control
    MARVELL : PHY reset
    INFO : PHY[0.0] - Checking link...
    INFO : PHY[0.0] - Link not yet established , restart auto-negotiation...
    INFO : PHY[0.0] - Link established
    INFO : PHY[0.0] - Speed = 100 , Duplex = Full
    OK , x=0 , CMD_CONFIG=0x00000000
    MAC post-initalization : CMD_CONFIG=0x04000203
    [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
    mctest init called
    IP address of et1 : 0.0.0.0
    But...now I still not Catch IP ... and LED message indicate is not denormal.
    (LED_TX unright)
    I try of de2-115 board test web_server_socket , and function is normal.
    (LED_TX right) so ... I exclude Internet cable problem of possibility ... I
    think maybe is my TX_DATA Problem...
    This line
    --- Quote Start ---
    --- Quote End ---
    shows that your board isn't getting an IP. Try to set a static IP address in the code yourself or use a DHCP server.
    Dear Daixiwen
    I setting static IP address of file simple_socket_server.h
    but TX_LED just bright look and unright...and I try use super terminal ,
    but still not connect ... (I have set SSS_PORT)
    Do you see the correct address in the nios console? If not it means the Interniche Stack isn't picking up the IP address you set.
    You should try and use a sniffer such as Wireshark to see if the board is answering any ARP requests.
    I have solved the problem by locking the address of all the components in the NIOS II processer! This problem confused me several days. At last, I remove it!
