9 years agoDownloading ELF failed
What do I do if I have the error "Downloading ELF failed" in Nios II SBT? I built a system in Qsys that had 0 errors, it compiled and I could load it to the board. What is then the error ...
9 years ago --- Quote Start --- Also while you are generating the qsys project. Just have a look in to the files in the pop up where the message appears as generated successfully. Is there nay error or warning as FWD_pointer or something. OR you can go to nios command shell in qsys<tools. Just have a look if this message popups or not. --- Quote End --- There is no indication that I'm doing anything wrong before the end. And then the error can be anything. Such a debug environment is not good where the error can be anything and waits until the end to generate error msg.
