9 years agoDownloading ELF failed
What do I do if I have the error "Downloading ELF failed" in Nios II SBT? I built a system in Qsys that had 0 errors, it compiled and I could load it to the board. What is then the error ...
9 years agoAre you running the project after connecting to any DE board. Also after you build the project. Go to quartus compile the project and dump into FPGA. And then comeback to eclipse and select run as hardware.
