9 years agoDownloading ELF failed
What do I do if I have the error "Downloading ELF failed" in Nios II SBT? I built a system in Qsys that had 0 errors, it compiled and I could load it to the board. What is then the error ...
9 years ago --- Quote Start --- The Nios II data master is suppose to be connected to AVMM Slave of the jtag uart. Same goes with the timer. You debug_reset_request in your Nios II should be connected to the reset of jtag uart. And disconnect it from the clk_in_reset and nios_ii_gen2_reset. Refer to this: http://www.alterawiki.com/uploads/4/45/hello_world_lab_manual_max10.pdf and connect the debug_reset_request of nios ii to the jtag_uart_reset. --- Quote End --- I get an error message in Qsys Error: system.clk_0: clk_0.clk_in_reset must be connected to a reset source If I connect it then I get same error again. Nothing works.
