9 years agoDownloading ELF failed
What do I do if I have the error "Downloading ELF failed" in Nios II SBT? I built a system in Qsys that had 0 errors, it compiled and I could load it to the board. What is then the error ...
9 years agoI'm gonna check it.
but you still have to check. is your clock(clk_0) working? is you reset_n signal pulled high? you need to check.
