9 years agoDownloading ELF failed
What do I do if I have the error "Downloading ELF failed" in Nios II SBT? I built a system in Qsys that had 0 errors, it compiled and I could load it to the board. What is then the error ...
9 years agoyou have to check those.
1) reset_n do you give reset signal to nios? at least you need to give signal which stuck high. or a pulse it becomes low once is better. 2)JTAG uart. if your Qsys does not have JTAG uart. you have no way to connect with your Qsys. 3) clock. you certainly need clock after all. you need double check if the clock is correct.
