11 years agoDownload a design with SRAM Object File containing this instance
Hi guys,
I am unable to run the signal tap as it shows the instance not found message on STP. 1. I cross verified that STP is enabled and linked to project. 2. Deleted db and incremental db folders. I am unable to know the root cause of the issue. If anyone faced same problem please share it. Thanks in advance. RameshNo RepliesBe the first to reply
