17 years agodoubt in nios
what are the file formats that EPCS device will support?
17 years ago --- Quote Start --- You can't create non-volatile ram inside a fpga. If you have small nios projects you can either store your programm in an epcs device which you need to configure your fpga or for bigger programms in an external flash ram. I think it's more comfortable to use c-code than (v)hdl-code. --- Quote End --- thanq for the answer
