JChoi2
7 years agoDoes tx_outclock of ALTLVDS_TX have to be connected to dedicated clock output pin?
I use Stratix V/ Arria10 Device. I made serdes with ALTLVDS_TX. I want output tx_outclock of ALTLVDS_TX to pin. Does tx_outclock of ALTLVDS_TX have to be connected to dedicated clock output pin?...
Rahul_S_Intel1
7 years agoHi ,
I would recommend you to use dedicated clock pins for jitter performance. The jitter level is low for the dedicated clock pins comparing to regular IO.
And I also recommend you to do the compilation on Quartus to make sure that the pins are compact with IO assignments
