JChoi2
7 years agoDoes tx_outclock of ALTLVDS_TX have to be connected to dedicated clock output pin?
I use Stratix V/ Arria10 Device. I made serdes with ALTLVDS_TX. I want output tx_outclock of ALTLVDS_TX to pin. Does tx_outclock of ALTLVDS_TX have to be connected to dedicated clock output pin?...
JChoi2
7 years agoThank you HPB
>As tx_outclock generated from a PLL,
In my case, the outclock divide factor is 2,
then tx_outclock is generated from serdes, the tx_in of serdes is "10101010.."
tx_outclock is one of the serialized data output port of channel.
In this case also, dedicated clock output has better jitter than regular I/o?
JC
- HBhat27 years ago
Contributor
TX_outcock is generated by internal PLL itself by taking inclock as the input. The PLL itself divides the reference clock to required frequency and outputs at tx_outclock port. So, in my view, it is better to connect to "PLL_xx_CLKOUT" pin of same bank where tx_out is placed.
With regards,
HPB
