11 years agoDoes the 'remote update' block actually work on Cyclone V?
I'm trying to get the 'remote update' (ie the reload the fpga from EPCQ) block to work on a cyclone V using quartos 14.1. I've managed to expose the epcq pins to 'user' logic and can successful...
11 years agoI think the vhdl I have is much the same as that referred to by the wiki page.
Certainly my avalon slave does much the same as the referenced code. I have a bit of nasty logic to divide the Avalon clock down by a factor of 4 (from 62.5MHz to just over 15) but I don't think that is causing grief. (It uses the falling edge to generate a mask for the clock, so removes three of every 4 clock pulses.)
