WhittierChen
3 years agoDoes the jic file in flash play a role in the download process of the sof file
During the test of our products, we found that the FPGA did not work properly. We downloaded a SOF file on the FPGA under the test environment and found that the NIOS software program started normall...
KellyJialin_Goh
3 years agoHi,
Any updates from your side? Are there any further clarification needed from my end?
Hope to hear on your findings.
Thank you.
Kelly
WhittierChen
3 years agoNo, I know how to generate jic files. As you know, using nios requires the .elf file generated by nios in the process of generating .jic files. I want to know whether the .sof file generated by pl and ps after compilation includes the .elf file compiled in nios? If not, after the .jic file has been downloaded into the flash, power up the FPGA, and then download the corresponding .sof file. Will the part of the nios program in the .jic file be read from the flash?
