WhittierChen
3 years agoDoes the jic file in flash play a role in the download process of the sof file
During the test of our products, we found that the FPGA did not work properly. We downloaded a SOF file on the FPGA under the test environment and found that the NIOS software program started normall...
KellyJialin_Goh
3 years agoHi,
Greetings and welcome to Intel's forum.
Here are some relevant information on your queries:
To generate .jic programming files with the Intel® Quartus® Prime software, you must first generate a user-specified SRAM object file (.sof), which is the input file. Next, you must convert the .sof to a .jic file using the Convert Programming File dialog box.
To integrate a NIOS II software project executable ELF file into a Quartus II hardware project SOF file, you may refer to this video for further information: https://www.youtube.com/watch?v=joFaxLY-rUE
Hope this could clear your doubts.
Thank you.
Kelly
